I am trying to export a skeleton to maya and apply a rig to it there. The problem is, that the fbx has the local transform of the joints exported into the rotation of the joint (instead of the joint orient). This is problematic when rigging in maya. Is there a way to get the joint orientation exported correctly?
export skeleton to maya via fbx
483 3 2- ronald_a
- 35 posts
- edward
- 7733 posts
- ronald_a
- 35 posts
Yeah, thats what I ended up doing. I also scaled up the mesh and kinefx skel by 100 to achieve scene scale conversion because using the expoter’s conversion would have the root joint be scaled by 100 which would freak out camera framing on joints in maya.
But I guess there won‘t be too many chances to run into fbx/maya weirdness in the future anyways…
- _Christopher_
- 767 posts
