Tested finaly:
Houdini DSO error on 'libnvidia-ml.so'
libnvidia-ml.so: cannot open shared object file: No such file or directory
Houdini DSO error on '/usr/lib64/libnvidia-ml.so'
/usr/lib64/libnvidia-ml.so: cannot open shared object file: No such file or directory
KarmaXPU: Failed to load CUDA DSO
KarmaXPU: Found 1 total devices
KarmaXPU: Device 0 Info: Embree CPU device
I've tested on latest priduction build 20.0.688
Nvidia 550.67
I seems to have it fixed.. I just copied libnvidia-ml.so.1 to libnvidia-ml.so in that /usr/lib64 folder...
XPU stopped working after Houdini upgrade (605 to 653).
3311 35 4- Mirko Jankovic
- 108 posts
- ajz3d
- 479 posts
Mirko, it seems to me that Fedora uses different paths to store NVIDIA libraries than Debian does. But it's the same path problem, where
You can ping the support using my bug report #151421. Because manually creating a symlink or copying a file is just an improvised solution, which may hit you back on the nearest system or nvidia-driver upgrade. Unless you remember to remove the symlink/file before initiating the process.
libnvidia-ml.so
isn't in the same place as libcuda.so
.You can ping the support using my bug report #151421. Because manually creating a symlink or copying a file is just an improvised solution, which may hit you back on the nearest system or nvidia-driver upgrade. Unless you remember to remove the symlink/file before initiating the process.
Edited by ajz3d - April 30, 2024 20:18:51
- brians
- 481 posts
- mzigaib
- 953 posts
Getting a little late to the discussion but I start to have issues to render on viewport or render gallery, it is crashing.
It is not everything but things that was working on previews versions are making Houdini crash now, not sure if it is a driver thing.
I am using Fedora 40, Houdini 20 build 688 NVIDIA driver 550.78
Render on Mplay is working fine.
Edited by mzigaib - May 6, 2024 14:21:28
- ajz3d
- 479 posts
- brians
- 481 posts
mzigaib
No idea what this is sorry.
Please put together a repro scene + clear steps, and file a bug report.
thanks very much
- Mirko Jankovic
- 108 posts
- Mirko Jankovic
- 108 posts
One more update on this issue.
I've run into problems with maya on same machine as well, now tested rocky linux and everything seems to work fine including Houdini 20.0.653 that had problems detecting GPUs on Nobara 39 (fedora 39), so seems like fedora hade some changes implemented or something. If it makes any sense. In any case. Rocky Linux 9.4 here at the moment and everything seems to work just fine
- mzigaib
- 953 posts
- keyframe
- 1532 posts
mzigaib
This is likely unrelated, but I came here looking for "550.78" and this was the only reference I could find.
Having all sorts of crash drama here since I've upgraded to this driver, and Rocky9.4.
G
- brians
- 481 posts
- mzigaib
- 953 posts
- keyframe
- 1532 posts
- keyframe
- 1532 posts
- mzigaib
- 953 posts
- mzigaib
- 953 posts
