getParameters not reflecting newly added data
   3613   2   0
I'm trying to write some Python to explore HAPI in depth (for example be sure of which parmType is any node)
I have written some Python code into a Python Script node directly in Houdini and using an inprocess session to connect.
I'm retrieving a specfic node from a path and listing the infos by using hapi.getParameters on the node in question.
I have defined a multiparmList in the node. When I add multiparm instances it is not reflected in the listing.
Same thing if I edit the parameter interface. I can only get the new parameters if I restart Houdini altogether.
example :
Session : <hapi.Session: type=sessionType.Inprocess, id=0>
Session is already Initialized
Node to query : /obj/test/
NodeId : 2
NodeName : test
Type : nodeType.Obj
TotalCookCount : 6
Valid : True
Number of params: 40
Multiparmlist ===
MultiParmList : <hapi.ParmInfo: id=37, type=parmType.Multiparmlist>
Number of multiparm childs : 2
=== Child ===
float1 : <hapi.ParmInfo: id=38, type=parmType.FloatStart>
TemplateName : float#
=== Child ===
Int1_ : <hapi.ParmInfo: id=39, type=parmType.IntStart>
TemplateName : Int#_
Here is a reduced version of the script I am currently using :
import hapi
session = hapi.createInProcessSession()
try:
    hapi.isInitialized(session)
    print("Session is already Initialized")
except:
    print("Session not Initialized, initializing")
    cook_options = hapi.CookOptions()
    hapi.initialize(session, cook_options, use_cooking_thread = False)
def stringFromSH(nameSH):
    str_len = hapi.getStringBufLength(session, nameSH)
    name = hapi.getString(session, nameSH, str_len)
    return name
nodeToQuery = hou.chsop("/obj/HAPI_Explorer/inputNode")
node = hapi.getNodeFromPath(session, -1, nodeToQuery)
nodeInfos = hapi.getNodeInfo(session, node)
parmInfos = hapi.getParameters(session, node, 0, nodeInfos.parmCount)
for p in parmInfos:
    print(stringFromSH(p.nameSH) + " : " + str(p))
Edited by anthony_rey - Oct. 4, 2022 10:44:57
Interesting. I've never used inprocess sessions and also never used python API.
I'm usually using thrift sessions and enabling session sync from client application. With this approach I don't see this behavior.
In your example I get correct result only if I set any parameter from client. Even if I just set it to the current value. So the possible workaround is just setting any parameter on the node to its value.
v = hapi.getParmIntValue(session, node, "some_int_parm", 0)
hapi.setParmIntValue(session, node, "some_int_parm", 0, v)
hapi.cookNode(session, node, None) # it's also important to cook the node on the client
I'm not sure why it's working like that and also not sure if it's intended to use hengine like that inside houdini itself.
It's consistent with what I have seen when using thrift sessions and session sync, I guess I'll have to keep doing that instead of doing it directly inside Houdini !
Thanks !
