Houdini 14 Viewport Issue
8049 7 1- Game Maker
- malexander
- 5205 posts
- Game Maker
No errors after setting the value to 1..
Actually I noticed that there is no option in Houdini 14 to set the OPEN GL version for the Scene Renderer. Earlier versions used to have this option in Prefs/ 3D Viewports/ Scene Renderer
May be its an OpenGL error. But having updated the Graphics driver also did not help
- malexander
- 5205 posts
- wombat780
- 3 posts
- q7204k
- Terry Morgan
- 4 posts
- jaspreetkaurchurch
Ilya Bakhtin
Hello, I need help with the same problem - notebook Dell Latitude 3450 with Intel HD 5500.
HOUDINI_OGL_DUMP_SHADER_ERRORS - doesn't help.
P.s. On the image you can see a box and a sphere (Shaded Bounding Box mode)….well, some sort of it =\
P.P.s. So far only “Hidden Line Ghost” works.
Here i am sharing some ideas with you that may be resolve your issue:
-Try to install latest driver version.
-Also make sure that the application/software that you are using should be updated.
-Restart your laptop and try again later.
If still issue exits then take support from Dell Latitude 3450 Manual- guideusermanual.com/product-name-latitude-3450-manual&po=344601&lang=English
