Hi Guys,
I've been looking in the Houdini help but I can't find out how to merge all the components of an object together eg. points, unused poly's ETC.
You can do it in C4D with the optimze command. Any help would be much appreciated
Equivalent Houdini command to C4D's 'OPTIMIZE' ??
3118 1 1- benandaim
- 32 posts
- JColdrick
- 4140 posts
I don't know any of the subtleties of the C4D workflow, but from what I can ascertain you'll probably want the Facet SOP. It will consolidate points and much more. There's also the quick and dirty Clean SOP, which is a subset of Facet and is typically used to clean up imported data.
J.C.
J.C.
John Coldrick
