whenever i load up my houdini master (apprentice version 6.1) i get an error message saying "FATAL ERROR: SEGMENTATiON FAULT. data saved to <directory>
is there a patch? i tried reinstaling like 5 times, and getting it from the website again
but nothin seems to work. please help me!
thank you for your time
-paul
FATAL ERROR: SEGMENTATION FAULT (?)
33978 15 10- techno-jew
- 3 posts
- tallkien
- 225 posts
- techno-jew
- 3 posts
- NatXotic
- 40 posts
- EigenAlex
- 639 posts
- NatXotic
- 40 posts
- EigenAlex
- 639 posts
- nz16
- 1 posts
- st0per
- 3 posts
- st0per
- 3 posts
- Filip Tarczewski
- 38 posts
st0per
i advice you to search for System Variable on here. I just added one with a value of1. This had something to do with my graphics card.
Steve
Could you elaborate? What was the name of the variable you added?
EDIT: I just noticed how old your post is
Edited by Filip Tarczewski - Sept. 23, 2016 06:07:52
- rpdacosta
- 11 posts
- Enivob
- 2625 posts
Can your computer pass the prime95 2 hour [mersenne.org] test? Give it a try, it might be your hardware is faulty.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- infernam
- 1 posts
Hello every one, I´m new in Houdini and got the apprentice version 16.
After installing, everytime I try to run it, it crashes, I´ll add a screen shot, I have tried the solutions that I have been reading here but none seems to work since it happens just after Houdini starts.
In one of the crashes it did sent an error: 4568: Fatal error: Segmentation fault
Saving application data to CUsers/infer/AppData/Local/Temp/houdini_temp/crash.untitled.infer_4568.hipnc
This is are the settings of my Lap:
ASUS
GL702VMK
Intel Core i7-7700HQ 2.80GHz
NVIDIA GeForce TRX 1060 GDDR5 3.0 GB (192-bit)
1TB 7200RPM SATA HDD
128GB SATA3 SSD
16GB RAM
Thank you people! have a great day
ASUS
GL702VMK
128GB SATA3 SSD
16GB RAM
- peetter
- 1 posts
Hi all,
I am new to Houdini. I am having exactly the same problem as infernam. Houdini crashes immediately after start, or very soon afterwards, just creating a cube and moving it around crashes it. The same error message:
¨4568: Fatal error: Segmentation fault¨. The number can be different. I have tried different solutions suggested in other similar posts, like deleting config folder, etc, but nothing works.
Windows 10 Pro updated
American Megatrends Inc. 1701, 25/03/2016
Motherboard Asus Maximus VIII Hero
Intel Core i7-6700 3.40Ghz 4 Core
Nvidia GeForceGTX 1080 with drivers 384.94
32 GBytes DDR4 Ram
Hope for some help. Thank you!
32 GBytes DDR4 Ram
Edited by peetter - July 27, 2017 09:46:02
- neil_math_comp
- 1743 posts
infernamThis forum thread was started in 2003; recommendations from that long ago would not be helpful. Unfortunately, people keep bumping the thread.
The most likely causes are Windows 10 pushing bad graphics drivers (it's automatically installed bad graphics drivers in the past) or something as-yet-unknown to do with Qt5, probably somehow interacting badly with Windows 10 or bad graphics drivers. (I'm on Windows 10 now, and I don't run into this issue with Qt5 and an NVidia Quadro M6000, so it's not everyone.) Could you try downloading [www.sidefx.com] and installing the Qt4 build?
