can we achive this sim in houdini ???!!!
   2636   4   0
Hi every body..
I tried a lot to get this thin mesh and fine detailed milk in houdini but i coudn't.. is that possible in houdini or houdini is only for the large scale sims??
link to the video:-
https://vimeo.com/29163247 [vimeo.com]
isn't thin film in RealFlow achieved via heaps of particles - have you tried the same in Houdini?
What do you think about Houdini ?
I believe that you can do anything in the Houdini.
Making this simulation is very simpler than you think.
Just use one Flip solver with two different source.
the first source is a Flip Tank for Milk and the other source is a object source for Honey.
Then you should just add two point attribute for each source ,Density and Viscosity ,Because Honey and Milk should be have different behavior.
Also you can add a different ID attribute for Honey and Milk , Then use this ID attribute for isolate Milk and Honey particles for making surface mesh with different color and material.
:wink:
Rabiee.Sadjad@Gmail.Com
I made a simple project for you ,Just to achieve more detail for Milk drops , Increase Particle Separation for both source object :!:
JKMilkHoney.zip (168.0 KB)
thanks a lot Joker this was so helpful , sorry I just noticed your replay today ops:
thanks a lot man…
