ocean wave pattern repeat
5982 6 2- igou
- 102 posts
I created a ocean with ocean fx. it's looks super great and just one problem, the pattern repeating is very obvious even I set the grid very big.
I dive into oceanspectum sop to tried to modifier the pattern noise but can't found the node which can control noise…orz
if i want to modifier the noise, where I can find this node? or other idea can fix the problem,please? :cry:
- igou
- 102 posts
- igou
- 102 posts
- Sadjad Rabiee
- 1391 posts
- Sadjad Rabiee
- 1391 posts
- igou
- 102 posts
Hi Joker,thanks the example!
I didn't get what you mean at first, but now I understand I think.
btw, when I set Griz Size bigger I can see the displacement map be more complex in comp. but my ocean surface's scale will look smaller!?
anyway Grid Size is seen difficult to control but I guess it is I need. I just have take more time to try it :wink:
and this is some my testing result. it's better than I expected!
- LI Black
- 1 posts
igouCan you send me your project file?
I want to learn about it.
1252569093@qq.com
