Hello. please help me understand what I'm doing wrong.
I am trying to do a simplified rigid body emitter, based on this technique:
http://valeriodinapoli.blogspot.com/2013/02/houdini-how-to-create-rigid-body-emitter.html [valeriodinapoli.blogspot.com]
I managed to do it from scratch in H13, but somehow it doesn't work in H14.
My procedure is as follows:
1) Create a RBD Point Object, using a grid (template) and a sphere (instance)
2) Put an expression in the DOP network, on the grid's RBD packed object node's Creation Frame parameter: if($F<100,if($F%3==0, $F, 0), 0), to emit new rigid bodies every third frame.
As soon as i lay down the expression in H14, the simulation disappears. Oddly enough if the modulo condition is set to $F==1 it plays, but the Rigid Body Solver node still errors out. It says Rigid point attribute “name” not found, and “Geometry doesn't contain any packed primitives”
So my question is: what has changed since H13, and how can i fix the no name and no packed prims errors?
H14 - Rigid body emitter
5370 4 2- Filip Tarczewski
- 38 posts
- cwhite
- 748 posts
- Filip Tarczewski
- 38 posts
I see. Thank you, I will try it with the new build.
For now i found that everything works if you choose RBD Point Object instead of the RBD Packed Object.
Is there a good guide to building these things from scratch, explaining all the settings of DOP Import / RBD Packed Object and their uses, apart from the help card, that anyone could point me to?
- useruser
- 6 posts
hi filip,
you can find a different method for creating a RBD-EMitter in this this tutorial-series:
https://vimeo.com/102198238 [vimeo.com]
but i still try to find a solution too which uses RBD-packed or the possibility to use instanced geometry instead the copy-sop because it slows the simualtion quickly down.
- useruser
- 6 posts
hi filip,
