Issue setting up agent transition graph. help please?
   4516   5   2
I am having a problem setting up the agent clip transition graph. I cannot seam to get it to work. Please take a look at the screengrab of my setup.
I am grateful of any help or if there are any examples please?
Many thanks
Mark
Without a file it's hard to tell what the issue is. Did you look at the example file provided in the docs?
Hi…
I only set it up as per the jpeg. I will try to send a file later thanks..
I could not find an example file I the docs?.. Is it possible you could point me I the right direction please..
Thanks.
Mark.
Hi…
Thanks.
Mark.
There's an example file named ‘ClipTransitionGraph’
Found the file…..and I have it working
Many thanks
Mark
