I am new to Houdini and I would like to check the possibility to integrate Houdini in our content generation pipeline. The experiment I would like to run is:
1. An artist create asset in Houdini (currently a simple digital asset that creates a sphere geometry and exposes a parameter for the radius)
2. In custom scene editor (c++ based app) a programmer should develop a way to expose a function to add a sphere in the scene with a given radius. This should demonstrate adding procedural assets in the scene using Houdini, with the understanding that in the future more complex assets can be used.
for step 1 Artist created helloWorld.hdanc, is this correct?
for step 2 Programmer needs to write a Houdini engine plugin for the custom c++ app? is there any representative sample that could be relevant to us?
HDK documentation, Houdini engine documentation, I am confused which one we should use and what these API's are called?
thanks,
Emanuel
Houdini Engine integration in custom app with c++
5577 3 0- emanuelshalev
- 7 posts
- edward
- 7714 posts
1. I don't think Houdini Engine supports non-commercial HDAs (ie. those created from Houdini Apprentice). I think you need at least an Indie license and create helloWolrd.hdalc. See also https://www.sidefx.com/forum/topic/39238/ [sidefx.com]
2. I don't know if this is too much but you can check out the HoudiniEngineFor* projects at https://github.com/sideeffects [github.com]
3. HDK is for writing Houdini plugins. To integrate Houdini Engine, you use the Houdini Engine API [sidefx.com]. Just noticed that there's “Full Source Samples” in there as well.
Edited by edward - March 29, 2017 01:12:03
- emanuelshalev
- 7 posts
- edward
- 7714 posts
