Ocean Surface H16
   3281   1   1
Hello!
I can't get to work the new ocean surface setup, even with the provided scene files. I the viewport it's seems fine, but it renders flat. (and without the foam)
Yes, I baked the spectra node.
Can anyone point me in the right direction? There is none learning material about the new ocean surface, not a single tutorial, only the masterclass.
Hi Friend. Years later I still have the same problem as you! have you ever found a solution to this?
