Hard Constraints/Connect Adjacent Pieces
   2025   0   0
Can anyone offer advice with hard constraints? I am trying to create hard constraints along voronoi fracture edges (that will break after certain parameters are met) and I'm having trouble defining the connections for the constraints. What I am currently trying is scattering points and using connect adjacent points (as seen in this video: http://bit.ly/2BgVfwQ [bit.ly] ) I feel like I'm missing something since there is a version difference. I want to create constraints between points within a search radius, and not have the points outside the radius still showing. I also cannot seem to get the connections from using adjacent points to work as a hard constraint (but when I use pieces from points it works as a constraint). Is there any advice for this? Thank you.
