attrfrommap
   2138   2   0
Hello, i have a one problem with this node why doesnt work? I set UDIM toggle in node but node use only one file in udim sequence…. I bring alembic file from 3ds max..
Edited by Grigrory Sadovnikov - Feb. 2, 2018 07:14:51
You may need to use a special token in the filename.
https://www.sidefx.com/forum/topic/49473/ [www.sidefx.com]
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
you can find the syntax on various places in help, but essentially you'll need %(UDIM)d token to replace the udim number in your path
http://www.sidefx.com/docs/houdini/nodes/vop/texture.html [www.sidefx.com]
http://www.sidefx.com/docs/houdini/vex/functions/expand_udim.html [www.sidefx.com]
FX Supervisor
Method Studios, NY
