Hi all,
I've been playing around with the crowds stuff in houdini 16.5 and I keep running into an issue with getting a custom crowd agent created from an imported FBX file to collide with RBD objects. I have no idea what exactly I'm missing, I've even recreated the example houdini ragdoll using my custom agent character instead of the inbuilt character from the houdini shelf.
No matter what I do my custom character doesn't collide with any ground or RBD objects. I've setup the custom agent limits and collision layer shapes.
If I rebuild everything using the inbuilt character from the houdini shelf the collisions work, but when I use my custom character created from an imported FBX file no collisions work at all.
not sure what I'm missing.
Thanks for any help.
crowds & RBD collision
3946 4 2- skyfire
- 4 posts
- Enivob
- 2625 posts
It could be that your custom agent mesh has a hole in it? Perhaps the eye sockets? You can't construct a water tight collision mesh with a source mesh that has holes. Try applying a PolyFill before you bake.
Edited by Enivob - April 25, 2018 09:28:22
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- cwhite
- 748 posts
- skyfire
- 4 posts
I've checked for holes in the mesh and I couldn't find any holes, it's all one mesh.
I can see the guide geometry from the collision layer and my crowd state is set to animated static. As far as I can
the bullet solver can also see all of the collision objects. When I toggle the show guide option the objects turn
to a blue colour.
When I run the sim I can see my character go from the animation to the ragdoll state. It's just my character doesn't
collide with any of the RBD objects or the ground, it just goes straight through everything.
I'm using very simple objects as RBD objects like box/ball shapes.
to a blue colour.
- mahialise
- 5 posts
