Terrain turns transparent problem.
3147 5 0- apaza610
- 33 posts
- dpernuit
- 550 posts
- apaza610
- 33 posts
Thanks for answering dpernuit, did you mean I could use the “objectMerge” node to turn the curve into an INPUT? cause I did that and the terrain is still Transparent, (new HDA attached). Or is there a file I could study with an editable road for UE4, thanks again and sorry for bothering…..
Edited by apaza610 - Sept. 11, 2018 16:43:18
- dpernuit
- 550 posts
Yes, what I meant was removing the editable curve node, and replace it by an input (so an object merge, with the objpath param exposed on the HDA).
The way you set it up was not working because the object merge was not replacing curve1 (so, connected to transform1).
Here's an updated version of your hda with the editable curve node replaced by an object merge input.
The only issue with setting the asset this way, is that you can set a default “state” for the curve.
- apaza610
- 33 posts
- apaza610
- 33 posts
