HOUDINI 17 installation failed, help!
   4149   1   2
Hey, guys, I install Houdini 17 Learning Edition. I can't help opening it. Error: REQUIRED CPU NOT FOUNO
A processor with SSE4.1 instructions is required to run this application. / 8 \ If you believe this machine meets the above criteria, please contact SideFX immediately. Otherwise, set the environment variable HOUDINI_DISABLE_SSE to 1 to avoid seeing this message in the future.
It's very gloomy. Houdini 17 doesn't support AMD's CPU?The CPU-Z test CPU instruction set is:MMX(+), 3DNow!(+), SSE, SSE2, SSE3, SSE>4A, xS6*64, WD-V ,Hei guys, what's the solution?
bijianchang
Modern AMD CPUs have had SSE4.1 for about the last 6 years. It's unfortunate that you seem to have one of the old ones that only supports SSE4a. Sorry.
