Delete constraint connections
   2804   4   1
Hi everybody,
I am trying to delete the constraint connections by Sop Solver attach to constraint network when the constraint downs below the 5m in Y axis.
Is it possible?
Thank you very much.
Hey
Do you want to kill constraints by their Position or Movement !?
If yes, First of all you need to copy position of the pieces to the constraints inside Sop Solver, Because as you know they are fixed in the Sop Solver.
to do this you can import pieces from Dops to the Sop Solver, Then Simply copy P attribute from them to the Constraint with same “name” attributes. (you can do this via either VEX or Attribute Copy SOP)
After that because your constraints are moving, you can kill them by Position or movement very easily.
I'll send you an example file.
Rabiee.Sadjad@Gmail.Com
Here you are
JK_KillConstraint.hip (320.5 KB)
Thank you very much Sadjad Rabiee!!
Sadjad Rabiee
Here you are
thanksss for the help!!
