Has anyone done Adrian Meyer's cell Replication tut & been sucessful adding the hair?
I've tried a few ways but can only get the hair to work on one side of the split.
https://vimeo.com/329020210 [vimeo.com]
Because the geomatry is changing & animating my guides seem to work fine when the constrait node is selected but the vellum solver, after the first split, doesn't add or sim the new hairs on the new split geomatry.
I'm also not sure if I'm putting the hair in the correct part of the setup.
I'm putting it into the import_cells node which adds the hair after the geo is made not while it's made.
The problem seems to be with the Vellum solver checking for guides every frame. if I start the Vellum sim after the first split the new guides are used for both cells correctly new & old but no hairs up to that point & when another split happens the original problem still stands no guides/hairs on the new split.
Any help would be great guys I've been trying diferent things for 2 weeks now.
Thanks guys
Steve
Adrian Meyer's Cell Split Hair
535 0 0- StevieMac
- 1 posts
