Newbie having problems with Attribute Wranlgle, pls help ;-;
   1849   1   0
Hey guys!! I just started using Houdini like 4 days ago and I'm already addicted.
But somehow when I try to use the Attribute Wrangle the points are going downwards and not at the centre… Any help on how to solve this problem will be welcomed.
Tips and Tricks are also welcomed
Thanks for the help
Levi
P.S: I'm trying to follow along the tutorial on how to create a thanos portal by Nine Between.
Well, you haven't defined the value for @F so Houdini defaults to using 0 which means your using whatever value is at position ‘zero’ of your chramp.
Also, your creating assigning a value for the velocity attribute (v@v), the teal colored guides in your scene are showing you the direction of the point Normals; not velocity.
Your best to post a hip that gives more access to the whole scene rather than screen shots. That makes more information available for someone to help troubleshoot.
Edited by BabaJ - Feb. 24, 2020 22:18:08
