Node Data Blocks
   1844   3   2
Hello!
I was just wondering if anyone ever managed to use the data blocks provided as part of the hou.Node API because I couldn't find any example anywhere?
I can't seem to get them to work at all, e.g.:
>>> hou.node('/').setDataBlock('foo', 'bar', 'str')
>>> hou.node('/').dataBlock('foo')
  File "<console>", line 1, in <module>
  File "/opt/houdini/18.0.287/houdini/python2.7libs/hou.py", line 11045, in dataBlock
    return _hou.Node_dataBlock(*args)
ValueError: Unsupported data block type
I did try with a variety of types such as 'int', 'char', and others, but no luck so far.
Edited by ChristopherC - May 4, 2020 16:34:14
It looks like a bug to me.
You can assign data, but never read it back.
node = hou.pwd()
# This all works.
node.setDataBlock("id","1","int")
node.setDataBlock("name","chris","str")
print node.dataBlockType("id")
print node.dataBlockKeys("int")
t = node.dataBlockType("id")
k = node.dataBlockKeys(t)
print t
print k
#This fails.
#print node.dataBlock("id")
#This fails.
print node.dataBlock(k)
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
I'm assuming so too—I just submitted a RFE for it.
Hi, did you ever hear back about this?
From some testing I think you have to pass `None` for the 3rd argument and in python 3 the value should be a `bytes` type (I think a `str` type in python 2).
E.g.
> n.setDataBlock('id', '1'.encode(), None)
> n.dataBlock('id')
b'1'
> n.dataBlock('id').decode()
'1'
> n.setDataBlock('test1', pickle.dumps({'a': 1}), None)
> pickle.loads(n.dataBlock('test1'))
{'a': 1}
