Noobie Manipulator / Network question :
According to hdox/houdini/content/base/handles_show.html
“To show the manipulators for an existing node, select the node in the network editor and press Enter.”
I'm using 8.2.13 (Apprentice) on Win XP, and I can't get this to work.
E.g. in SOP's, I add a Box, then a transform (Xform) operator, and then platonic (Teapot), then a transform. I then connect the Xform's to a Merge op.
If I then select either of the Xform's in the network editor, and press Enter, with either the mouse cursor over the network editor or the 3d viewer, nothing happens. Isn't the manipulator supposed to re-appear ?
The only way I've found to make the manipulators appear is to press “s”, then re-select the geometry I want to work with, but this keeps adding extra Xform opeators into the network pane.
Do I need to have “Make all Handles Persistent ” turned on (from the Operator / Persistent Handles menu?
Mike
Use Manipulator
11607 9 2- mstram
- 77 posts
- Joe
- 483 posts
- mstram
- 77 posts
Joe
To re-select for the current operation, use the back-tick ` key. What happens when you press enter is to get the handles for the current operation, maintaining the current selection.
I tried the back-tick, didn't work either.
I thought I explained it clearly, I'm trying to unselect everything … select the Xform node then have the transform handles / manipulator appear. Is it possible to do so ?
Mike
- metreom
- 5 posts
- Ondrej
- 1081 posts
Two possible problems.
1. Make sure that you are pressing Enter in the viewer, not the network editor.
2. In SOPs, by default, you get the manipulator for the SOP with the display flag when you do this. That being the case, you'll want to move the display flag to the node in which you're interested. The other option is to go to the Operator menu in the viewer pane and change “Show Display Operator” to “Show Current Operator”, and then you'll just need to click on the node in the network editor without having to move the display flag.
- gaucho
- 14 posts
- Moose
- 52 posts
OndrejThat's good to know indeed.
I've just bound these options to a couple of hot keys, but I'd prefer it if I could use just the one hot key as a toggle instead - is this possible?
- Ondrej
- 1081 posts
- Moose
- 52 posts
- mstram
- 77 posts
