exporting a geometry as one combined piece
   1042   0   0
Howdy,
I've been working on creating a piece that can be repeated to fill space using voronoi. I used line and resample nodes to create the framework and used voronoifracture and rbdcluster to create the shape. I used blast to separate the main piece I need(the_piece) for the repeating process. I tried to test that if the piece can actually fills up the whole space by using boolean subtract with a box. However, There are many slices/faces remained as in the image that shows the surface of the pieces are not fully closed and combined together. I would really appreciate your help. Thank you!
week_07_demo_v01_checkPiece_cleanup.hipnc (260.0 KB)
