Redshift ramp without UV
   2461   1   0
Using Redshift to render and wanted to use a RSRamp node but it only seems to work with UVs which my model doesnt have as its a large scan.
Other Nodes like the noise nodes create without needing UVS. Is there a way to use maybe the rest attribute?
As a work around I created a attribute wrangle and mapped Cd to the bounding box of the mesh. I brought this into Redshift using the color user data node, means I have to go out of the material network to alter that ramp which isnt so handy.
Can anyone advise on a better way? I suck when it comes to rendering so thats why currently trying to level up.
Many thanks
Hey captainbuckfish,
why don't you apply a texture projection to your geometry? Other than that you can try the Labs gradient tool.
it creates a ramp via point colors.
cheers
CYTE
