autorigcomponent
's transformdriver require a special joints orientation? You can see that the skeleton flips in the attached file and there is some stretching going on. Just trying to recreate the Electra's example scene.
[SOLVED] autorig transformdriver joints orient issue
976 2 2- Ivan L
- 199 posts
Does
Edited by Ivan L - Dec. 10, 2023 10:21:52
I contribute to the beauty of this world
https://houdininotes.ivanlarinin.com/ [houdininotes.ivanlarinin.com]
- Ivan L
- 199 posts
It looks like it's a requirement from APEX for the root joint to be oriented with Y axis along the child. Which is weird cus the
orient joint node
works quite opposite orienting joints with Z as a main axis by default. It breaks stuff
Edited by Ivan L - Dec. 10, 2023 10:22:29
- esttri
- 76 posts
