There is a lesson about animating modeling and animate mushrooms on Patreon. I started today and one of the first node we use is Skeleton but this node doesn’t exist in my Houdini.
I use the latest Apprentice downloaded and activated with the launcher. I did several install and uninstall, read on forums, Reddit I could find but nothing.
Have you already faced this kind of issue? Or any idea? I was so motivated to learn after work. It’s been 3h I tried to find a solution.
Thank you
Skeleton node missing
550 2 1- Cordell
- 5 posts
- EZiniT
- 53 posts
You're currently at the "Object Level".
Create a "Geometry Node" and double click on it to go inside you'll see your level changes from "Object" to "Geometry" (top right of the network view).....The Skeleton node will then be available.
Sometimes certain nodes can only be created in a specific context, a little confusing at first but it soon makes sense as you dig deeper.
- Cordell
- 5 posts
EZiniT
Thank you ! That was such a noob thing, omg Thank you so much!
