Hello all, I have a crowds agent set up with many clips, everything is set up in the agent transition graph and works perfectly when tested in the test_sim Crowds transiton node. As soon as I apply in the dop net, my transition chain seam to be skip or really fast and dosen't reflect what I have in the testsim_crowdtransition node. I did check the Use transition node in the crwod transition node and everything is loaded properly in the crowd object
any help would be really appreciate. Thx
Transition Graph dosen't load in SIm
453 0 1- Gregg Stankowski
- 2 posts
