Attribute Transfer Normal (N) it's not recognized
   677   1   1
Hey I've Some problem here, i follow the turoial double jump exactly. and when i put attribute transfer and type N on point its not work, any solution?
Are you sure your Normals are on your points and not your vertices? Try transferring them to your vertices instead, or promoting them to your points before your transfer.
