We want to remove (or at least hide in the interface) a built in test geometry.
How would we go about removing the shaderball test geometry and add our own version of it? Can this be done on a filesystem level or does it require using the hdk?
Removing/hiding default operators
741 3 2- GoCeltics
- 13 posts
- ObeidaZakzak
- 123 posts
There's an HScript command to hide nodes ophide [www.sidefx.com]
Using the command will hide the node for the current Houdini session, so to make it work always you can setup a script called
Now if you make your version of this HDA then you should change the namespace, like
OPcustomize
under HOUDINI_PATH
with the ophide command inside. For example, look at how it's setup with SideFXLabs [github.com]Now if you make your version of this HDA then you should change the namespace, like
company::testgeometry_shaderball
- GoCeltics
- 13 posts
We got this hscript hiding technique to work which is awesome.
Is it possible to see the "code" for built in ops? Like shaderball for example. Grepping around in /Applications/Houdini shows that it might be .../Versions/20.5/Resources/houdini/usd/assets/shaderball/payload.usdc or a couple of other places - but what if we want to extend/modify the builtin test geometries? Or just see how they are built?
Edited by GoCeltics - Oct. 2, 2024 17:27:20
- ObeidaZakzak
- 123 posts
Shaderball and other test geometries are all Digital Assets. You can unlock them and dive inside their subnet and see how they are built. Usually their geo is saved under bgeo files and embedded in the HDA, you will notice this when you check the file path in the File SOPs used inside thses HDAs.
Regarding the usd files, they are saved here to be used as a reference when you use a test geometry in LOPs.
