snap to an edge
   722   6   3
Hey guys I am struggling here to snap in the middle of an edge. Have tried a lot of options in the snap menu with no success, the only snap that is working (at least for me) is grid snap. What am I doing wrong? Thanks!
Timeline 1.mp4 (14.1 MB)
Hi have you tried to set the priority to the highest level?
Snap to edge mid position? [www.sidefx.com]
viklc
Yes...still not working
Possibly a Vulkan bug. Try switching to OpenGL.
A left field suggestion: Could it be a view point illusion - and that pivot point / handle is not at the location it seems to be? Mid-point edge snapping is working OK for me using Vulkan.
Sometimes snapping to geometry that is currently being edited doesn't work. In such cases, try to template the preceding node (PolyBridge SOP in your case), and see what happens. You should be able to snap to it.
Edited by ajz3d - Oct. 21, 2024 12:56:16
I get that a lot as well, where snapping stops working, especially at SOP level.
But sometimes it does still work in another view. When this happens and I switch to the top-left view ( default Top-view ), instead of the top-right , snapping works again … when I’m lucky.
