I'm trying to cast data stored in voxels into 64-bit doubles for simulation precision purposes. Is this viable? I couldn't seem to find an "attribute cast" sop for volumes. @jlait
Thanks,
Peter
64-bit Voxels?
1393 3 0- bwu
- 5 posts
- animatrix_
- 4693 posts
Hi Peter,
I doubt regular volumes support 64bit precision, but VDB volumes do. So you can use that. But if you are using DOPs, I don't think you can retain 64bit precision without doing a trip back to 32bit volumetric representation.
- bwu
- 5 posts
- animatrix_
- 4693 posts
Could probably do these calculations on points with a 64bit attribute and then transfer the result back to a regular volume at the end. That's probably what I would do.
