I had version 19 installed previously.
I am on V 14.1 (Sonoma) of the operating system. I tried reinstalling the Houdini itself as well as the license server.
I see a splash screen and then crash.
crash log look like this:
Crash report from 6d16d9c7; Houdini FX Version 20.0.547 [macosx13-arm64-clang14.0-targetosx10.15]
Uptime 4 seconds
Fri Dec 22 22:05:50 2023
Caught signal 11
2 libHoudiniUI.dylib 0x0000000101f4e984 AP_Interface::coreDumpChaser(UTsignalHandlerArg) + 588
3 libHoudiniUI.dylib 0x0000000101f50628 AP_Interface::si_CrashHandler::chaser(UTsignalHandlerArg) + 64
4 libHoudiniUT.dylib 0x0000000108654f50 signalCallback(UTsignalHandlerArg) + 608
5 libHoudiniUT.dylib 0x00000001089e34a0 UT_Signal::processSignal(int, __siginfo*, void*) + 112
6 libsystem_platform.dylib 0x0000000184487a24 _sigtramp + 56
7 libsystem_c.dylib 0x00000001843017b0 flockfile + 24
8 libsystem_c.dylib 0x0000000184305bdc fseeko + 76
9 libHoudiniUI.dylib 0x0000000101cd75c8 (anonymous namespace)::ui_AutoCacheWriteMutex::~ui_AutoCacheWriteMutex() + 76
10 libHoudiniUI.dylib 0x0000000101cd7270 UI_IconSVG::createCacheFile(char const*) + 220
11 libHoudiniUI.dylib 0x0000000101cd5c84 UI_IconSVG::findAndCreateRasterCacheFile() + 1044
12 libHoudiniUI.dylib 0x0000000101cd96d0 UI_IconSVG::getPixelRasters(int, int, UT_Array<std::__1::unique_ptr<PXL_Raster, std::__1::default_delete<PXL_Raster>>>&, bool*) + 164
13 libHoudiniUI.dylib 0x0000000101cd9304 UI_IconSVG::initTexture(RE_Render*, int, int, bool*) + 96
14 libHoudiniUI.dylib 0x0000000101cdae04 UI_IconSVG::preloadIcon(RE_Render*, int, int) + 288
15 libHoudiniUI.dylib 0x0000000101cd0214 UI_IconBase::preloadIcons(RE_Render*, bool) + 256
16 libHoudiniUI.dylib 0x0000000101de83a4 UI_Window::doRedrawSubclass() + 284
17 libHoudiniUI.dylib 0x0000000101de8270 UI_Window::doRedraw() + 256
18 libHoudiniUI.dylib 0x0000000101d68dc8 UI_Queue::doWindowRedraws() + 624
19 libHoudiniUI.dylib 0x0000000101d689b4 UI_Queue::processNextEvent() + 808
20 libHoudiniUI.dylib 0x0000000101d6860c UI_Queue::drain() + 88
21 libHoudiniUI.dylib 0x0000000101d67eb4 UI_Queue::drainEvents(bool, bool) + 288
22 libHoudiniAPPS2.dylib 0x00000001042b2c58 OPUI_MainApp::onUiCreated(UI_Event*) + 40
23 libHoudiniUI.dylib 0x0000000101d68998 UI_Queue::processNextEvent() + 780
24 libHoudiniUI.dylib 0x0000000101d6860c UI_Queue::drain() + 88
25 libHoudiniUI.dylib 0x0000000101d68f18 UI_Queue::eventLoop() + 140
26 libHoudiniUI.dylib 0x0000000101f57500 main + 6864
27 dyld 0x00000001840dd0e0 start + 2360
Not sure if important, but server installation had a warning (From logs):
[22:07:37 Internal] Run `launchctl load -w -F /Library/LaunchDaemons/com.sidefx.sesinetd.plist`
[22:07:37 Warning] Warning: Expecting a LaunchAgents path since the command was ran as user. Got LaunchDaemons instead.
`launchctl bootstrap` is a recommended alternative.
I don't know what else I can do in this situation. I am happy to drop absolutely everything, including launcher and try again.
I did try to restart - that didn't help.
