this maybe will sound like a silly question but…
in what node I can change the smoke temperature? I want to create a cold smoke effect.
I've already tryed to create a Volume ramp node after the isooffset node (inside an object node). and when I change the value of the right marker in the Scalar Ramp tab to -1, the smoke disappears instead of falling down.
so I presume this is not the right node to chane the temperature.
change smoke temperature
3851 3 0- criscornellius
- 14 posts
- criscornellius
- 14 posts
- criscornellius
- 14 posts
well. no reply until now
in the meantime i found out something
changing the value of the Temperature Diffuse (AutoDopNetwork>smokesolver1) makes the smoke fall down or rise up. maybe this is what changes the temperature.
anyway in the houdini 11 version, the Source from object button is absent.
I read somewhere that now the button Source from Volume does the same thing.
- criscornellius
- 14 posts
