Point cloud attributes
   1545   1   1
Hi Guys, I have a point cloud finding some points which is working as I expect.
How can I access the attributes of the individual points found in vops?
Pete
You can use vex code in a wrangle to access each point. Typically points will have only the “P” attribute, maybe “v” for velocity if they are moving.
Also, try viewing the Geometry Spread sheet with the node selected. You should be able to see the attributes in spreadsheet form.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
