i can't seem to drag and drop throughout the houdini interface
when i am in the material pallette i cannot drag and drop from the galleries into the shop context….
i cannot drag and drop materials onto objects…
and i cannot drag and drop parameters into expressions or other channels
something i'm missing here? some environment variable I have to enable?
Nvidia 470 on win 7 64 bit Intel I7
thanks
can't drag and drop through out houdini
12058 16 3- m.d.
- 34 posts
- m.d.
- 34 posts
- robertbutterworth
- 1 posts
Yeah I have been having the same issue and I have worked it out in my case.
My setup is 2 Dell 24" on Windows 7 x64 with Houdini 11.0.581:
It only happens when you have 2 monitors and the second monitor has a lager height resolution.. I have also noticed that the startup logo is not centered on my second screen where I mostly use it.
Hope this helps.
~B)
Hope this helps.
~B)
- specs
- 2 posts
- grayOlorin
- 1799 posts
Hey specs, I have the same problem too. If you actually drag your mouse around the window a bit, you should be able to find a spot to drop your asset (ie bottom right of window).
I do not know about dropping materials on objects. I have not tried that. But dragging stuff off galleries to other windows works fine this way
-G
- specs
- 2 posts
- enthewhite
- 20 posts
- jcereijo
- 1 posts
- grayOlorin
- 1799 posts
- kni8_2k
- 18 posts
- xyzDist
- 8 posts
- grayOlorin
- 1799 posts
- Anonymous
- 678 posts
- pbowmar
- 7025 posts
- ken748647
- 1 posts
- Yi Liang Siew
- 16 posts
- andrewmcbrideatl
- 8 posts
