udims workflow in karma
2871
5
0
Piledriver
May 6, 2022 12:34 p.m.
Hi, how i can import multiudims texture and read them as udims in karma and if it's also supported in materialx standard surface, thanks in advance
Edited by Piledriver - May 6, 2022 14:49:43
jsmack
May 6, 2022 12:44 p.m.
What's a multiudim? is that different than a regular UDIM texture atlas style?
Piledriver
May 6, 2022 2:49 p.m.
i mean that infact
jsmack
May 6, 2022 3:15 p.m.
Piledriver i mean that infactThen you just load them in the normal way, the same as with mantra. Use the file browser set to UDIMs or enter the path to the texture with the token <UDIM> in place of the tile number in the path.
Edited by jsmack - May 6, 2022 15:15:35
Piledriver
May 6, 2022 4:18 p.m.
thanks, i didn't used mantra before
May 7, 2022 10:23 a.m.
If you have two or three tiles it would be something like this. imagename.1001.exr imagename.1002.exr imagename.1003.exr Load up the first file and rename to imagename.%(UDIM)d.exr
Werner Ziemerink
Head of 3D
www.luma.co.za
