What's the best approach to scale TBIK? The problem is that the scale transform is not being passed and the geometry is not scaled accordingly.
Scaling Two Bone IK
879 8 3- guilhermecasagrandi
- 274 posts
- edward
- 7760 posts
- Magnus_Mller
- 285 posts
- 274 posts
Magnus_Mllerguilhermecasagrandi
Add the scale to the rest input of the TBIK, should work
Yep, it worked thanks, but not the way I expected. To get the correct results I had to scale the whole skeleton to get the correct rest values.
- Magnus_Mller
- 285 posts
guilhermecasagrandiMagnus_Mllerguilhermecasagrandi
Great! Depending on how you are scaling it you need to make sure the world positions of the rest is also set, so that's to be expected. So if you're only scaling the arm you should be able to scale the shoulder with scaleinheritance to True
Magnus Møller
Creative Director / Rigger @ Tumblehead
- 0chumpy
- 12 posts
- edward
- 7760 posts
- 0chumpy
- 12 posts
edward
Please submit your hip file demonstrating this as a bug, thanks!
the chicken rig was made with smoothik, try promoting the scale parameter of the root_ctrl,
then scale that control in the scene animate sop, you'll see what I mean. I've sent a RFE of it
often times i rig on unit scale model just to have a safe reference with distance base parameters of other sop
node, then i just reapply those at the root_ctrl to bring it back to the modeled scale.
Edited by 0chumpy - March 12, 2024 02:49:21
- Magnus_Mller
- 285 posts
could it be that the smoothing factor is a world space based? maybe that one needs to be scaled too?
I tried to use the smoothIK but gave me to many headaches so I switched back to the twoBone IK instead. Would love to see the smoothIK get some more polish
Magnus Møller
