Only seeing uv'S and not the shader.
   185   1   1
Hey here, this might be a noobie question, but I'm having a problem that I only see the UV map created on my vellum object and can't seem to disable it.
Pictures are below.
First one is the node setup.
Second is the Render view and third is the Scene view.
The colliding objects and backdrop seem to work fine, so I suppose its in the uv nodes. but I can't seem to find it.
Edited by TJoovel - May 7, 2024 11:19:36
The visualize uv node applies a material on your geometry through the shop_materialpath attribute that will take precedence over materials assigned to objects. You can disable it or delete the attribute downstream.
