possible randomize particle radius in solaris?
   469   1   1
Hi, my question it's if should be possible to randomize the radius on particles/instances or any other attribute but directly in solaris randomize them like using a wrangle or python lop?
Yes you can set the Attribute Wrangle to Run on Elements of Array Attributes, and set or adjust attributes/primvars as needed. Python could also work, but you'd probably want to use Numpy to be performant.
I'm o.d.d.
