Hello, I'm brand new to Houdini and trying to make some Game meshes. I can't figure out if this is my graphics card or there is something wrong with my model but in a nutshell I get this black mesh instead of white when trying to voxelize. I can send a file to anyone who wants to take a look at it. Anything helps
and I am sorry if this has already been asked on here.
Black mesh instead of regular White when trying to Voxelize
985 11 0- dparcell87
- 6 posts
- Enivob
- 2558 posts
One thing to try, is to assign a default material. Then make sure the viewport Material button is turned on (it is by default), and activate the lighting with shadows button. You may want to add an area light or environment light as well.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- maitlandvt
- 9 posts
might as well attach a file, it could be hard to tell/people just guessing otherwise...
maybe a guess: your normals are pointing in instead of out? that always makes things look super weird... try adding a normal sop or a facet sop after you convert to polygons. also there is a new quad remesh sop that will prolly come in handy.
hope that is helpful
~Maitland
~Maitland
- dparcell87
- 6 posts
- dparcell87
- 6 posts
oh and here is a file link if anyone wants to take a look https://drive.google.com/file/d/1eUX5awZHXS1o7R-rxIZT3PaTQqkBHNAz/view?usp=sharing [drive.google.com]
- maitlandvt
- 9 posts
- dparcell87
- 6 posts
Here is the Houdini file
and here is an FBX
https://drive.google.com/file/d/1kS0vZrFA1LujRRA-s7jzZwoROO_IrDqF/view?usp=sharing [drive.google.com]
and here is an FBX
- Enivob
- 2558 posts
- dparcell87
- 6 posts
Oh Okay, thank you! Again I have no F%#king clue what I'm doing in this software I just know there is a technique where I can take my sculpted and kitbashed models and optimize them faster so I can throw into Substance and texture for pieces of 3d Concept art. Any pointers on the technique I am mentioning, I'm all ears.
Edited by dparcell87 - May 3, 2024 11:45:01
- maitlandvt
- 9 posts
yes try the new quadremesh node its greaet! also, try the instant meshes (labs) is a good one, if quadremesh doesn't get you there. (you also need to install instant meshes, but it is free and open source.)
Also, if you are trying to bake it to a substance, well you might want to start with some simpler geometry. Just try kitbashing a simple grid, then baking your grid out to a displacement map (for instance). then apply your kit bash displacement map, and finally apply your displacement map to your main geometry.
you can UV your main geometry (just the cylinder) using the "labs UV unwrap cylinder" node.
Make sure and install the SideFX labs tool set, that will help you a lot (click Labs->update labs at the top. if you are on steam, then get sidefx labs from the github)
also, take a look at this video, if you haven't seen it,
https://www.youtube.com/watch?v=gfS6ylg9vbA [www.youtube.com]
This "Simon Houdini" dude on youtube has some good techniques, you might also find something from this video:
https://www.youtube.com/watch?v=N7CDHwgWKVo [www.youtube.com]
I hope any of that helps! best way to learn houdini is to get in there and play around, ask some questions, and watch some videos!
- dparcell87
- 6 posts
Enivob I used that RemeshGrid node because I was following along with this tutorial https://www.sidefx.com/tutorials/high_res_mesh/ [www.sidefx.com] which is a lil dated I know, which is kinda why I was asking questions here thinking the software has changed a lil since then. Have any of you seen this tutorial at all?
- maitlandvt
- 9 posts
hey, i didn't really figure out why, but i *did* figure out WHAT your problem is. have a look at your geometry spreadsheet (in the default view, it's a tab next to the viewport). click on vertices and you will notice that after you lay down remeshgrid sop, your "Cd" (color) point attribute has been flipped from white (1.0,1.0,1.0) to black (0.0,0.0,0.0)...
the thing about it is, it doesn't even really matter, it just looks weird. you are completely changing the points when you remesh it, so they don't really line up the same way. if you had colors you cared about, then it would be a bigger deal...
so, it's really nothing, it's prolly just a bug in that node.. or its just that it doesn't have values for those points so it just gives them a 0.
you could just fix it with a color sop or just use the quadremesh node instead. (which actually deletes the Cd point attribute). just use a color node, and yer good. throw down a normal node while your at it.
There have been a number of changes since that video came out, but i'll have a look at it, because i like to watch houdini videos more than i like to watch cartoons haha...
