Hi. Why do I need to re-split the viewport every time I open a file I am working on and load Redshift in one of them? Shouldn't Houdini remember the layout if I continue working on the same file?
I understand I can save a UI in Houdini. In this case, I do not need to save the UI as the default; I just expect the scene layout to look as I left it in the last session.
Thank you
UI resetting every time I open a saved file
367 3 1- zooropa
- 15 posts
- toonafish
- 413 posts
- zooropa
- 15 posts
- toonafish
- 413 posts
You can send an RFE here: https://www.sidefx.com/bugs/submit/ [www.sidefx.com] as well as reporting bugs.
Its a Request For Enhancement
Edited by toonafish - April 26, 2024 07:34:38
