Hi everyone,
I am getting an error whenever I try to blackbox HDAs.
File "<stdin>", line 17, in <module>
File "C:\PROGRA~1/SIDEEF~1/Houdini 20.0.625/houdini/python3.10libs\digitalassetsupport.py", line 39, in create_instance return _create_vop_instance(node_type)
File "C:\PROGRA~1/SIDEEF~1/Houdini 20.0.625/houdini/python3.10libs\digitalassetsupport.py", line 105, in _create_vop_instance
assert not "Could not determine the VOP context for this VOP asset"
AssertionError
This happens for some HDAs and some blackbox correctly. I am not sure if it is because these HDAs are Material X nodes & Material VOPs (guess I saw the same thing happen randomly with Vex VOPs in shaders as well) or is it because I had previously saved the HDAs as a different name and did a "Save As" to rename the HDAs and format the names correctly or is it some other issue?
Any information or help would be really helpful!
Error Black Boxing HDAs with Material VOPs or Material X
167 0 1- sharanvaswani93
- 14 posts
