Evaluating mantra as a rendering solution for an upcoming gig. Just wanted to make sure it wasen't too painful for us to retrain some guys doing lighting in houdini. This didn't take me too long to dail in. Nice renderer.
I used a car as a prettier shader ball for testing, helps illustrate problems with hilight compression on curved surfaces very well… mantra was a champ with sampling that stuff. I was coming at this with a bunch of lightwave, modo and mental ray experience.
Cars have most of the smaller surfaces set to a black plastic (lenses inside the headlight housings, tires, interior…) but the paint, glass, and rims look pretty much right.
mantra surface and ray trace pbr
PBR tests (now with more than just cars)
12607 11 2- Mike_RB
- 78 posts
- zarti
- 330 posts
- 3Dude
- 39 posts
- Mike_RB
- 78 posts
- 3Dude
- 39 posts
- Mike_RB
- 78 posts
- brianBurke
- 192 posts
- zarti
- 330 posts
the second frame of the roses is really beautiful !
it is good to see mantra used to produce such details , beside the usual dust'n'smoke'n'fire …
im really curious to see the level of detail of their geometry …
any wireframe screenshot ? what app is used to model those ?
.cheers
.cheers
- RAINpit
- 8 posts
- Mike_RB
- 78 posts
We have a job coming up that we need to wreck enough stuff that I'm reluctant to push stuff back into Softimage for rendering. Usually for us Houdini is dust/smoke and we comp it into MR renders.
As far as the flower petals go it's all modelling other than the veins which are textures.
And from my tests I'm not scared to render our standard robots/cars in Mantra. Seems more than capable in most areas and more capable than MR in mblur/displacement/dof world.
- RAINpit
- 8 posts
interesting. it's true that mantra feels more robust than mray,
the only drawback to me is how convoluted things are with building shaders
in houdini vs the xsi render tree.
though i'm curious as to why you would go with mantra
and not arnold for heavy raytracing/gi work.
i'm sure you guys have used it at least for testing purposes,
since you use xsi almost exclusively for rigging/animation.
if nda's allow for at least a personal opinion…
- Mike_RB
- 78 posts
