Procedural Tubes
   Views 31269   Replies 20   Subscribers 3
Sunday WiP of pipes, optimized and UV-mapped from just 1 curve.
/M
Personal Houdini test videos, http://vimeo.com/magnusl3d/ [vimeo.com]
Update, now I can copy stamp my subnetwork so it generates different patterns for each pipe. And it has become alot faster to generate the mesh
/M
looks cool! Can't tell if they are interpenetrating or not, so I guess it's fine .
https://www.linkedin.com/in/peter-claes-10a4854/ [www.linkedin.com]
looks great and impressive
pclaes, Thanks ! Well actually there might be interpenetrating since the “lift” factor was random, but I have no improved it so it takes previous layer hight + radius, only downside to that is that they became alot thicker, so I put in a multipler factor because you dont realy see intterpenetration that much as long as it's somewhat above …*phew*
roughsporty, Thanks ! what impressed me the most is the render times I get with Mantra, last pic was renderd under 5min..and since then I've improved quality and render times are still very good ..so making a little movie clip
/M
Realy impressive … and beautyfull images
yep ! , really cool and ala - houdini …
can you give us the possibility to observe ‘ from far ’ its logic ?
… any screenshot of network ?
.well done and cheers
yep, really impressive (as usual from you )
can we hope in a bit of tuto? It would be nice.
Thanks guy's ! I have put togeather a sample file, It should generate something that looks like the attached picture.
File was saved with 11.0.573
the sample file is a earlier version before I added more complexity and safe guards so it should be pretty straight forward ! except for my strange naming convention
It can be easily rebuild to use drawn curves to become the child pipes to, but I went for generating that too, meaning I can copystamp and get different pipes
Tubes_Sample.hipnc (803.9 KB)
/M
Thanks for sharing. Will study this one very closely…
Lu-Tze, dont hesitate to ask if something is unclear !
And here is the promised video render!
http://vimeo.com/17858177 [vimeo.com]
/M
Man this is amazing!
Thanks for the hip!
Thanks Magnus.
Houdini community is nice as usual
Игры на двоих [igri-vdvoem.ru]
Pretty nice stuff!
Remind mine RnDs on past October…
But mine has an option “as vine”:
looks great. The colour selection is quite nice as well..
So Impressive and Also rendered perfectly , Specially I like red lights on the second image :wink:
Rabiee.Sadjad@Gmail.Com
This is fantastic. Thank you very much for sharing the file.
Wow this is an amazing work of art, thanks so much for the file!
Super cool!
Thanks for sharing!
