Ray hit attribute transfer
   1967   0   1
Hi, I'm running v10.0.734, and would like to know if v11 (which doesn't run on my system) shares the following behaviour:
I'm using the ray SOP to transfer attributes from points on a surface, using the ‘Import attributes from hits’ option. The problem is that string attributes are not transferred. Please could you check the attached Houdini file in H11, and let me know if the texturemap attribute on the Ray SOP is blank for all points?
RayTransfer.hipnc (69.4 KB)
