hi~guys
i got a problem when launching Houdini on Ubuntu11.4….i try to fix~ but….
I have installed Houdini 11.0.701(apprentice) on Ubuntu 11.4, but when i run houdini in terminal, it shows a lists of error:
“/opt/hfs11.0.701/hsvg/hsvg-real: symbol lookup error: /usr/lib/x86_64-linux-gnu/libgio-2.0.so.0: undefined symbol: g_cclosure_marshal_VOID_VARIANT”
Even with this error, i still can launch houdini on ubuntu, but i got no icon in houdini, all the icons just simply displays as a white square. so,do you know how to fix this? Is this a problem relates to Ubuntu? i already seeking for answer from some linux online communities, but i still can't fix it.
anyone got idea how to fix this?
thanks in adsvance
Problem when launching Houdini on Ubuntu11.4
22340 21 5- VFXCSN0309
- 14 posts
- Alejandro Echeverry
- 691 posts
Hi!!
I have the same problem; I believe that is an ubuntu problem related with the display drivers.
Maybe is better to rollback to 10.10?
- VFXCSN0309
- 14 posts
- VFXCSN0309
- 14 posts
- Alanw
- 320 posts
Check out Edward's post in this thread.
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=17069 [sidefx.com]
There's a chance it might not apply, but it's worthwhile following along with the instructions there, and you can report back here with your results.
- 691 posts
Thank you very much Alan, Edward's solution works like a charm!!!!
Thank you!!!
Thank you!!!
- edward
- 7909 posts
- 691 posts
But it works for me after doing your fix.
I have run Houdini in two different hardware configurations, and now Houdini didn't have the icons problem with Ubuntu 11.04
Thank you.
Thank you.
- Kashir
- 3 posts
alejandroMe too!
[i54.tinypic.com]
Thanks edward & Alanw.
Greetings!
- uniqueloginname
- 330 posts
- graham
- 1922 posts
Sadly, as a long time Ubuntu user, I have to say that 11.04 is really a piece of trash. There are so many things wrong with it. Even getting rid of the awful new Unity system and using the classic desktop mode it still has a ton of issues that get in the way of any serious work. While Houdini does generally run okay on it, I would definitely recommend going back to 10.
- Erik_JE
- 299 posts
- Brahman
- 6 posts
Hi all,
Having a similar problem with Houdini 11.0.775 running on Ubuntu 11.4. Any new updates or insights to this problem would be much appreciated. I am getting the exact same error:
/opt/hfs11.0.701/hsvg/hsvg-real: symbol lookup error: /usr/lib/x86_64-linux-gnu/libgio-2.0.so.0: undefined symbol: g_cclosure_marshal_VOID_VARIANT"
I followed most of the recommendations (above) as best as I could (being new to Linux) and I managed to get the icons back, but the software is still not functioning as I cannot click on anything and then it freezes completely requiring a power cycle . I am running Win7 64 along side Ubuntu 64 via Wubi, on an HP 3.2 Ghz dual core AMD64 box with 5GB DDR3 RAM and a 2GB Radeon 5440 GPU. If there is no resolution to this, can someone point in the direction another user-friendly distro that works? btw everything works fine on Windows, but I have some expensive particle sims that I need to crank out for my demo reel, and I want to get the max performance. I saw someone else post that being new to linux it might not be worth it to make the switch, but I do know that most studios use Linux so I have to learn it anyway right? Thoughts?
Thanks in advance for any suggestions!
~Houdini Disciple
~Houdini Disciple
Brahman
- Erik_JE
- 299 posts
Brahman
Hi all,
~Houdini Disciple
If you wan't stable Houdini and easy to use I would install Ubuntu 10.04 LTS as already other pointed out.
11.04 the Natty Narwhal is just bad.
Drive, monkey, drive!
- Brahman
- 6 posts
- Brahman
- 6 posts
not successful running Ubuntu 10.04.3 The screen keeps going blank upon boot (monitors going in and out of sleep mode continuously) and I read it has something to do with loading the ATI graphics driver, and /or modifying the boot config in the grub menu. So I followed all the instructions including command only mode, but the prompt didnt stay there long enough to type anything like apt-get (for the ati driver) …it just disappears. Then I managed to get it to continue installing but was met with “Loop-mounted file system already present” errors. So I am about to give up on linux for Houdini this point I did however get Naiad working on U11.4 so I might just stick with that for now, and go back to the Ubuntu forums for help installing 10.40 later.
Brahman
- Erik_JE
- 299 posts
Brahman
Did you try not using the graphical install for Ubuntu? It sometimes got problems with various graphics cards.
- Brahman
- 6 posts
@Erik ,
I never did get around to a non graphical install on Ubuntu but I did try Mint4Win and it finally worked! I still had to use the hsvg cmd and mess around with the libs etc to get the icons back, so I dont know if my lack of success with Ubuntu may have just been my lack of experience with linux in general, and after pounding away at it for almost a week maybe I just got better navigating linux lol. Anyway, it is mostly working now and seems to be screaming fast (from a couple of fluid test renders I did), so very excited about that, BUT I do get this annoying flashing on the viewport, which randomly goes blank (grey background) and seems to go back to normal for a bit when I click in the viewport. I suspect it has something to do with the video card/drivers although I had no issues on win7 with that. I am running a 2GB ATI Radeon HD 5670. Any insights into the the flashing viewport would be cool.
many thanks
many thanks
Brahman
- Alanw
- 320 posts
Are you using the closed source ati-drivers or the open source version? If you're unsure X should have a log. Mine is /var/log/Xorg.0.log
The drivers from amd also have a utility called aticonfig, which you probably won't have otherwise. You can check if they exist on your system by typing “which aticonfig” from a terminal.
- Brahman
- 6 posts
Thanks for the reply. I do have the proprietary amd driver installed, and have the catalyst control center etc. Here is what is showing (attached). I ended up reinstalling Ubuntu 11.4 because I could not get Naiad working in Mint, but I am still having issues with the display and noticed the following error upon starting Naiad: “Unrecognised OpenGL version”. I am not sure why as I think I have the latest since it says in Catalyst I have “Open GL Version 4.1.10665 Compatibility Profile Context”.
Thanks for your help!
Brahman
