Make Breakable on certain RBD
   3197   3   2
Hello!
So here's my problem. I have a pre-fractured wall. What I would like to do is be able to pick one piece from this fractured wall and fracture it dynamically again with the “Make Breakable” tool. At first, before looking at the tool, I thought I'd be able to just select that piece and click the “Make Breakable” button and it would just work on THAT piece (because I have the wall falling a certain way or else I'd just simulate that ONE object separately). But unfortunately, it still does the dynamic fracturing on the ENTIRE wall.
Anybody have any ideas on how to do this? Thanks for any help!
You can do it by using RBD Glue Objects. then just use the Group Mask parameter to isolate the piece that you want to further break and add a Voronoi Fracture Configure Object to it. Setup the Glue to Object Parameter accordingly, merge everything together and voila!
Toronto - ON
Thanks for the response rafaels! I took the suggestions from you and one other post at odforce.
Unfortunately I don't see a “group mask” option for the voronoi fracture nodes in the autodopnet so I had to work around that.
Instead I just used “Grouped Dynamic Objects” on all objects BUT the one I wanted to fracture. Then I deleted that group, which isolated the one piece I wanted to fracture.
Seems to work alright. Thanks for the help!
Glad to know it worked though!
Just in case, for future reference:
Screen shot 2011-09-15 at 9.33.14 AM.png (35.5 KB)
Toronto - ON
