substr expression tip
   2207   0   0
Hi
string substr (string s, float start, float length)
Returns a substring of a string.
Using this expression you can evaluate the name of string and extract part of it ie
echo `substr(“my_string”, 3, 6)`
= string
Very handy when you want to write data out using a structure. but suppose other out nodes are not named as above. Mark on the list gave a simple answer for the float length just use a large number ! That way no matter the node name it will get automatically extracted out.
ie $HIP/`substr(opinput(“.”,0),4,10000)`.$F.bgeo
Rob
substring_example.hip (41.5 KB)
Gone fishing
