hi all.
i have a funny problem.
1. i get some geometry from DOP, with DOPimport SOP node.
2. i use “Create points for representing objects”
3. i need to retime cache, but TimeBlend don't work with “Orient” attribute (also “TimeBlendParticles” don't work with)
4. I need to import “orient” point attribute, but i can't use it as … variable value.
I mean i can use $VX $VY $VZ velocity, i can use $CEX(YZ), $MAPU, $MAPV
e.t.c..
How i can get $ORIENT ? How look right name for orient variable ?
$ORIENT0(123) don't work..
Orient attribute
13346 3 1- live_fx
- 160 posts
- 8833 posts
- derrick
- 332 posts
live_fx
The Attribute Create SOP can be used to create variables for existing attributes. Consider appending an Attribute Create SOP with the “Name” parameter set to “orient”, the “Size” parameter set to 4, and the “Write Values” toggle turned off.
- live_fx
- 160 posts
