Hey Guys;
I am having trouble installing an apprentice license on my mac. I'm on OS X Version 10.7.4 and have downloaded 12.1.33.
1. The Houdini License Administrator pops up.
2. I choose “Install (or reinstall) my free Houdini Apprentice license…”.
3. I click “Next”
4. I accept the “End User License Agreement”.
5. The window that says “The non-commercial licenses were successfully installed. What would you like to do next?” pops up.
6. I click ‘Run’.
7. The process starts over at #1.
License Server Keeps Asking to Install
16295 15 3- fxrod
- 133 posts
- Solitude
- 373 posts
- combi
- 4 posts
I encounter this exact same problem.
I'm on osx 10.6.8, and in the past, I had no problem with running houdini apprentice.
I tried the uninstaller, and reinstall latest version, but still it's still stucked into this perpetual license install asking.
Nicolas
Edit:
I just noticed that even if I choose the proper version on the drop down menu in the download page, I get this dmg:
houdini-12.1.33-macosx_x86_64_gcc4.2_10.7.dmg
Is it normal?
Nicolas
Edit:
Is it normal?
- fxrod
- 133 posts
Looking at my License Administrator. Everything is looking kosher.
The license server is running.
The license server is allowed to serve licenses
License Administrator can read and modify local licenses.
Going to send my diagnostic info to sidefx support.
BTW: This is happening on both 12.1.33 and 12.0.634
Francisco Rodriguez
Effects Animator | Walt Disney Animation Studios
- combi
- 4 posts
- combi
- 4 posts
- edward
- 7899 posts
From http://support.apple.com/kb/HT1810 [support.apple.com] it doesn't sound like stealth mode would impact the Houdini licensing. Perhaps you have some other firewall option that was blocking Houdini until you added it to the exceptions list.
- combi
- 4 posts
- fxrod
- 133 posts
I got a reply from Side FX that works. Seems like my licenses list was pretty backlogged and was confusing the server. All I had to do was delete the licenses.local file under /Library/Preferences/sesi (please do not confuse this with path with /users/username/Library).
Installing the license then worked! Thanks, Silvina.
Francisco Rodriguez
- bendstraw
- 3 posts
- kumara
- 3 posts
had same problem and tried all suggestions here (prior to reading them). The only thing that worked was installing license manually following instructions at: "http://license.sidefx.com/get_nc_license.php [license.sidefx.com]".
hth
hth
- zdimaria
- 390 posts
- WhoDjini
- 94 posts
I just had the same trouble on Win7_64.
Fired up Wireshark and had a look
URI: /client/get_non_commercial_license_auto.php?servername=xxxxxxxxxx&servercode=xxxxxx&version=12.1&products=RENDER-NC%3bHOUDINI-NC
then a look at
http://license.sidefx.com/get_nc_license.php [license.sidefx.com] reveals, there is no licence for 12.1 :-(
So I fired the last 12.0, let it get a licence, and retried Houdini FX (12.1) et voilá, it runs….
just felt the need to share!
HTH!!!
then a look at
HTH!!!
If you can't script/program it, it's no good at all !
- ben simons
- 387 posts
fxrodYes, I just had the same problem. I'd install a new apprentice license and it
would already appear used (hkey shows 0/1 available).
Running Houdini would just go in circles with an offer to install another
apprentice license. Fail. There were a lot of old licenses, for sure.
It might be the OSX hostname changed. it now seems to be blah.local.local
Renaming “/Library/Preferences/sesi/licenses.local” to
“/Library/Preferences/sesi/licenses.local.19Aug14” & restarting sesinetd fixed it.
At first hkey is unhappy. Running HoudiniFX and choosing to install another
apprentice license creates a new license.local file. Then you're good to go.
Certainly, the new long SERVER code in the new license file is different..
hope that helps.
''You're always doing this: reducing it to science. Why can't it be real?'' – Jackie Tyler
- gsoldier
Hello, I got the same problem
Here you have my diagnostic info :
License server is running: Yes
May read licenses from server: Yes
Has SERVER license: Yes
License server version: 16.0.504
May modify server from this machine: Yes
Redundant server keys: 1
Name Code Redundant Connected Transmission OK
****** ******* no - -
License Administrator version: 16.0.621
Http proxy host: (none)
Licensing options file: CProgram Files/Side Effects Software/Houdini 16.0.621/houdini/Licensing.opt
Using standalone mode: No
Can retrieve http://license.sidefx.com/index.php: Yes
Installed licenses:
sesictrl -i output:
—– SERVER ****** ——–
Serv *************
redundant: no
connected: no
transmission successful: no
I tried everything but houdini cannot connect to my license server, I don't know why, maybe because of the others licenses server I have, but I shut them all down but nothing works.
Installed licenses:
sesictrl -i output:
Serv *************
redundant: no
connected: no
- canimation907
